Log in Sign up
Posted by Zendure Team
Mobile phone devices like the Apple iPhone definitely make life much easier, especially for people constantly on-the-go. However, life can become much more stressful when the iPhone gets low on battery life or runs out of juice. An iPhone that lasts the entire day is what we all would love. Most of us have had to deal with such battery anxiety.
Today, it has become important to have a way to charge our iPhones when on-the-go, especially since most people spend a lot of time playing games, checking email, and spending time on social media sites such as Facebook. Heavy use of an iPhone can drain the battery before the end of the day. When that happens, a portable battery charger will become your best friend. But what is the best portable charger for iPhone?
Zendure-power-bank-for-charging-appleAbout Portable Battery Chargers
Portable chargers are one of the best solutions to preventing battery draining of your electronic devices. They come in a variety of brands, sizes, styles, and have various features. A portable charger can be pulled out of your carry bag, purse, or even pocket when your device needs some juice and you can charge your phone without needing a power outlet. All you need to do is charge it up at home, put it in your bag or your pocket, and connect it to your phone whenever a battery boost is needed, Depending on the charger, it can also recharge a compatible tablet, camera, iPad, iPod, etc. Some chargers can charge more than one device at the same time.The most powerful portable chargers can even charge a laptop.
How much mAh (power) you need in a portable charger depends on the time and usage by the user. If you use your phone a lot when you are on-the-go, then you know all about the problems of a drained battery. Battery capacity is rated by milliampere hours (mAh), which is the amount of capacity needed to let one milliampere of electrical current flow for one hour. The more mAh, the more power a portable has to keep charging. Whatever power capacity you need in a portable charger, there are a variety of options on the market that will fit your needs.
Zendure-battery-on-the-go-charging
What Makes A Quality Portable Charger for the iPhone?
There are a few key features to look for in a portable charger for the iPhone? Portability is essential to ensuring your iPhone never fails due to low battery life. A small lightweight charger is easy to carry anywhere. Speed of recharge is also an important factor to consider. For example, some chargers have built-in cables so you can put them directly into your iPhone. The majority of chargers have USB-A output sockets (the most familiar socket, also called USB) so you can plug in most charging cables. If the input or output are USB-C, charging may be faster in both directions.
There are also portable chargers which can recharge wirelessly. The iPhone 8 and later + and other compatible devices from Samsung, Sony, LG, Nokia, Huawei, Microsoft Lumia, Google, Nexus, and BlackBerry that can wirelessly charge. It is important to be aware that wired charging is faster than wireless charging. If you want a nice style and color, there are many appealing portable chargers for the iPhone.
Zendure-Power-Bank-For-All-Your-Needs
Zendure A3PD Portable Charger (10,000 mAh): An Ideal iPhone Charger
Zendure A3PD portable charger is an example of a quality charger that features fast and future-proof charging technology for the entire range of new USB-C devices. It provides fast charging of iPhone XS/XR/XS Max, iPhone X, iPhone 8, or iPhone 8 plus up to 50% in just 30 minutes due to USB Power Delivery. It provides high-speed charging for USB Type-C PD enabled devices up to 18W output.As well, with the small, reversible USB-C connector, Zendure A3PD has easy connection for power.
The A3PD is one of the smallest and lightweight external batteries on the market for its capacity. With 10,000 mAh capacity, this compact charger can easily extend your phone usage 3-4 times. This high-density battery provides 2.5 charges for iPhone Xs, 3 charges for iPhone 8, 2.1 charges for Galaxy S9 Plus and a charge for iPad. It will also recharge in 3X faster speed (when using 18W PD or QC 2.0/3.0 wall charger), compared with a 5W stock charger. It is a long-term battery since A3PD can maintain up to 95% of the original charge after six months without use. In addition, the Zendure A3PD Portable Charger has pass-through charging which means you can charge your iphone or tablet while the slim power bank is recharging.
Zendure-portable-charger-for-travel
An iPhone Portable Charger That Meets Your Needs
The best portable charger for your iPhone is one that meets your needs and lifestyle. You should be aware of what type of power user you are, or in other words, how much you are on-the-go and use your iPhone. Once you are aware of how much you will be using your iPhone each day, then you can look at the options available to you.
Zendure-chargers-devices-anywhere
